Shell Command Authorization Sets ACS
Gerson Acevedo
hi i followed this guide step by step http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
but still all my user  can use all the commands
version 12.4
hostname R3
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login milista group tacacs+ local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa session-id common
memory-size iomem 5
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username admin privilege 15 secret 5 $1$CS17$3oeNpzTvJAyZTvOUP2qyB1
archive
log config
hidekeys
interface FastEthernet0/0
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 20.20.20.2 255.255.255.252
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 20.0.0.0
network 192.168.20.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
tacacs-server host 192.168.20.2 key cisco
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login authentication milista
line aux 0
line vty 0 4
end
i copy the authorization commands from the cisco forum and follow  the steps but no thing all my users have full access to all commands
heres my share profile
name-------------admin jr
Description---------for jr admin
unmatched commands------- ()permit  (x)deny
permint unmatched args()
enable
show -------------------------- permit version<cr>
permit runnig-config<cr>
then i add this profifle to group 2 and then i add my user to the group 2
then i log in to the router enter with the user and i still can use ALL the commands i dont know what i am doign bad any idea?
can you  give me  if you can a guide to setup authorization with ACS i cant find any good guide  jeremy from CBT gives a example but just for authentication i am lost  i am battling with this  prblem since wednesday without luck
8 Replies 8
Nicolas Darchis
ACS 4 or 5 ?
On ACS, do you see authorization logs where the switch tries to ask for authorization for each command typed ?
is 4.2 for server 2003
and is a router my device and abouit the logs i am not using accounting  in my router yet that was the next step in my configuration but i am stuck here with authorization
I didn't say accounting. What do you see in "Tacacs authorization" logs on acs ?
excuse i cant find that option in the acs where is it?
reports and activity -> Tacacs+ administration
its in blank nothin appears  neither in the passed authentification log weird but ican log in using the tacacs+ all  my users there works
Vamsi Pinnaka
"you are testing with privilege level 15 or below 15. Because when you are using below 15 level user, first it will check local command authorization set. For example if you want to execute sh runn command with level 5 user, first it will check local command set. If the sh runn command exits in local command set then it will send request to ACS. If it is not in the command set, it won't send request to ACS. That's why you don't see debug. For 15 level users it will directly send request to ACS. Configure command set locally and try it should work.
Correct me if I am wrong."
Vamsi
solve it it didnt work the first time because i try it with the console after i try this config via telnet (log in) my users cant use all commands just the commands i added to the shell list
this config works
