show users problem
ddolbel
Level 3
Level 3
hi, i'm having a issue with show users on a cisco catalyst 3750
i'm logging in with a local user and I have tried logging in with a tacacs and radius account, when I do a show users on the switch it doesn't show the username,
however on the cisco 1841 router I have it shows the user information all the time,
if there a command I have to use on the switch to make it show user information ie username used to login, when the show users command is issued. I have tried to compare the configs however all the generic info seems to be the same.
ROUTER#sh users
Line User Host(s) Idle Location
194 vty 0 admin idle 00:12:37 10.0.0.13
Interface User Mode Idle Peer Address
SWITCH#sh users
2 vty 0 idle 00:12:37 10.0.0.13
I hope this makes sense
craig.eyre
Level 5
Level 5
I checked this on my 3750's and it works fine. Did you see if it's a bug in the IOS you are running? I'm running 12.2(40) SE
Craig
kernorlin
Community Member
This looks like someone hack to the network, isn't it?
TAIT6#show line
  Tty Typ   Tx/Rx   A Modem Roty AccO AccI Uses Noise Overruns Int
   0  CTY           -     -    -    -    -   0    0     0/0    -
  65  AUX 9600/9600 -     -    -    -    -   0    0     0/0    -
* 66  VTY           -     -    -    -    -  268   0     0/0    -
* 67  VTY           -     -    -    -    -  160   0     0/0    -
  68  VTY           -     -    -    -    -   31   0     0/0    -
  69  VTY           -     -    -    -    -    9   0     0/0    -
70 VTY - - - - - 5 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-64
TAIT6#show users
  66 vty 0      idle    02:38:55 47.116.17.144
* 67 vty 1 tait idle    00:00:00 192.168.10.222
Vi2            PPPoE 00:00:03 168.95.98.254
?  This post is from 2008.....
