Soution for ACS Replacement for Wireless and VPN Authentication?
Jim Matuska
We have been running Cisco ACS physical appliances for quite a few years for VPN Client (to our ASA Firewalls) and Wireless WPA2/AES authentication with our Cisco Wireless controllers.  In both instances we have ACS connected to active directory to do the actual userid/password verification.
The ACS products as I understand it are now nearing or at EOL and show the ISE products as replacements.  However, these seem to have a bit more functionality (and cost) than we need.
Does anyone have any suggestions for a solution to authenticate and log these wireless and VPN clients that doesn't cost a lot of money.
We are running VMWare so virtualizing servers is a preferred method if available.
What do you think?
Well if you don't want or need the functionality of ISE, then how about Microsoft Windows NPS, this can do basic 802.1x authentication for wired/wireless. It probably can't do the fancy stuff that ISE can (guest, web portals, tacacs etc).
Thanks for the info, I'm going to look into using NPS on server 2016. We are currently using PEAP-MSCHAPV2 and authenticating against Active Directory accounts for wireless clients. Is this still a good setup or is there a better option for authentication for wireless? Note, we want to keep the end user device configuration to a minimum, in most cases just choose SSID and put in domain credentials to authenticate.
What do you think?
Marvin Rhoads
ISE with Base licenses is the recommended solution. Migration from ACS is very easy with the provided migration tool.
Have you priced out ISE? There was a migration special offer last year for ACS customers but unfortunately that has expired.
