Strange Performance Issue with Pix/501 and Radius Auth
cdonner64
When I enable inbound Radius authentication for HTTP traffic on my Pix 501, inbound SSL traffic is becoming terribly slow, to a degree that the browser times out regularily. As soon as I turn off the authentication rulw, SSL zips along.
I collected all sorts of diagnostic and performance-related output in the attachement, but everything seems to be normal to me.
What should I do next?
ps: I should add that I am using IE and that the pages require a client cert, which is installed.
drolemc
Level 6
Level 6
I tried looking for a bug related to the behavior you are seeing but was unable to find any. I was wondering if it could be a configuration issue?
This issue is not critical and I have more pressing things to work on. I assume it is related to something else.
The browser prompts me to select a client certificate, which happens fairly quick. After that, it just hangs. When I hit refresh several times, i will eventually see the page and the images.
Again, when I turn Radius off, everything works normally. Considering that I change just one command in the Pix configuration, I woule not expect the effect that I am observing.
