SXP Connection Design
firefox
I am looking for a best practice guide for setting up SXP connections. I went through the basic ones that are available. I am looking for few suggestions on best setting up SXP tunnel between 9 C3650 switches. I observed that when SXP tunnels are setup in a mesh format with all the 9 switches, the CPU of the switch goes high. When its setup in a star format there is no issue with CPU. So, in this regard, is there a best practice guide to setup SXP connections, basically between switches? I do not have SXP between ISE and Switch.
TJ
Kevin Regan
Tiju,
If you cannot use inline tagging between the switches and need SXP, https://communities.cisco.com/docs/DOC-75763 may help, alternatively if you download Darrin Miller’s BRKSEC-3690 slides from CiscoLive you will find some more detail on SXP reflector designs and how to use SXP path length filters. They are important with SXP reflector designs (look around slide 100 in his most recent Orlando delivery).
A mesh approach should be avoided, SXP reflector will be much more effective, please note that the path length limits came in 3.6(5), 3.7(4) and 16.3 onwards.
If all of the users/devices are going to be authorized by ISE, you may find it simpler to send SXP from ISE directly to the switches, then the switches only need to be configured as SXP listeners.
Hope that helps,
Kevin
Kevin Regan
Tiju,
Hope that helps,
Kevin
