System Failure registering secondary to primary ACS
Heiko Kelling
I have the following situation. I have two ACS, a primary (ACS1) and a secondary (ACS2) with software version 5.1.0.44.2.
Because of a corrupted file system I had to reinstall the secondary ACS Appliance (ACS2).
I used the software version 5.3.0.40. All informations like user data, network devices....are
on the ACS 1, only. The ACS 1 is needed 24/7 and it is not possible to stop the services.
Because the ACS certificates were expired I had renewed them after the installation.
Now to the problem: If I try to register the ACS2 (5.3.0.40) to the ACS1 (5.1.0.44.2) I get a
system failure message
Could somebody tell me, if it is in principle possible the register a server with a higher software
version to another one, with a lower version? Or is the reason for the failure a certificate problem?
integreon
It's a bug (CSCtd39360). This got fixed in 5.2 version.
Anton
Hi integreon,
are you sure that this is the same problem?
I read the bug symptom in the bug toolkit and there is talk of "change policy Identity store to Identity sequences".
My failure is, when I try to register the secondary to the primary ACS.
But the wording of the failure is similar.
Thanks for now.
Travis Hysuick
Good morning,
I don't believe that you can join a server with a different software version to the ACS topology. I specifically recall reading in the 5.3 product documentation, (though I can't find it at the moment) that it is not compatible with previous versions (due to feature changes and likely significant differences in the database schema).
I would recommend you schedule an outage so that you can stop the ACS application services on the existing primary and secondary units and perform the upgrade to 5.3, as well as the subsequent 5.3.0.40.1 patch.
Once the units are all at the same version, try joining the new secondary to the topology again, but be patient. When you click the 'Register to Primary' button from the new secondary, it can take quite a while for the connection and replication to complete. During this time, the browser may appear to have stalled; leave it be. It will complete, however in my case, it took nearly 30 minutes (and this is with a relatively simple service policy set, your mileage may vary depending on how complex your service policies, user / group database is).
Travis Hysuick
CCNA Voice
