TACACS+ Administration Reports Problem
1aindyin2
Community Member
After we upgraded ACS to 4.1(1) Build 23 from 3.3.4 we no longer are getting information in the TACACS+ Administration Report Files.
aaa new-model
aaa authentication fail-message ^CC Login Failed, Please Try Again.^C
aaa authentication password-prompt Non_TACACS_Password:
aaa authentication username-prompt Non_TACACS_Username:
aaa authentication login default group tacacs+ local
aaa authentication login no_tacacs local
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa authorization network default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 0 NetAdmins start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 7 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
Jagdeep Gambhir
Level 11
Level 11
This is a known issue, you need to apply patch ACS 4.1.1.23.5 to fix the issue.
Patch for appliance is availble on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Patch name : ACS SE 4.1.1.23.5 accumulative patch
Patch for acs windows is availble on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
Patch Name : ACS 4.1.1.23.5 accumulative patch
That should fix the issue,
Jagdeep
Note: If that answers your question, then please mark this thread as resolved, so that others can benefit from it.
Jagdeep Gambhir
Level 11
Level 11
Jagdeep
