01-11-2005 12:43 AM - edited 03-10-2019 01:57 PM
I configured our access-point for tacacs and its working very well, but I want one more thing, web interface username&pass should use tacacs.
how can I do this?
Solved! Go to Solution.
01-11-2005 01:14 AM
I am using a 1200 but maybe it helps.
Through the Web Interface I can navigate to SECURITY > Admin Access and turn on an option called "Authentication Server if not found in local list". After turning it on I can use my username and password for the Web Interface and in the Telnet program.
01-11-2005 01:14 AM
01-11-2005 01:41 AM
AP1(config)#ip http authentication tacacs
or
AP1(config)#ip http authentication aaa
depending on setup.
