TACACS login problem
brymiller
Community Member
Here's the config:
aaa new-model
ip tacacs source-interface Loopback0
tacacs-server host 10.1.1.100
tacacs-server directed-request
Here's the debug:
R7#test aaa group t U1 cisco new-code
Trying to authenticate with Servergroup tacacs+
*Mar 1 03:17:17.816: TPLUS: Queuing AAA Authentication request 0 for processing
*Mar 1 03:17:17.820: TPLUS: processing authentication start request id 0
*Mar 1 03:17:17.820: TPLUS: Authentication start packet created for 0(U1)
*Mar 1 03:17:17.820: TPLUS: Using server 10.1.1.100User rejected
R7#
*Mar 1 03:17:22.824: TPLUS(00000000): Select Timed out
*Mar 1 03:17:22.824: TPLUS(00000000) Error connecting to socket 0
*Mar 1 03:17:22.824: %TAC+: no address for get_server
I can't find the sys message in the doc. Any ideas?
TIA
brymiller
Community Member
Disregard....
routing problem
Doh!
richardcalvert
Level 2
Level 2
did you assign the same server key to the routers config that you gave the tacacs server?
