Tacacs+ / secondary authentication method problem
ktokash
Community Member
I must be missing something here. I would like to have my routers use tacacs+ for authentication, and if all tacacs+ servers are unreachable have the admin able to get in with the enable password. I have the following aaa setup:
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication login vtyauth group tacacs+ enable
aaa authentication enable default enable
aaa authorization exec default group tacacs+
tacacs-server host 1.1.1.1
tacacs-server host 2.2.2.2
tacacs-server key [key]
Under vty config:
login authentication vtyauth
The tacacs+ works fine, but if I take out the IPs of the two auth servers the routers/switches don't let anyone authenticate at all. The box is a 3550 running c3550-i5q3l2-mz.121-14.EA1a.
gfullage
It's probably your authorization method, you haven't defined a backup for that so if TACACS is unavailable it'll fail.
Try the following:
aaa authorization exec default group tacacs+ none
to tell the router not to do authorization if TACACS is unavailable (you can't really do it locally), and see how you go.
ktokash
Community Member
Yes that did the trick. Thnx a bunch .
