The problem with importing Internal Users on Cisco ACS
Hrosik1985
I have a problem. Missing passwords or hash when I export the Internal User into CSV. In Template of CSV is columb "password:String(32):Required". But this columbs are empty in export file. Import CSV fails. The problem is missing "password:String" in import file.
HEADER (Template):
name:String(64):Required,description:String(1024),"dateExceedsEnabled:Boolean(true,false):Required",dateExceeds:Date(yyyy-Mmm-dd),"passwordNeverExpires:Boolean(true,false):Required","enabled:Boolean(true,false):Required","changePassword:Boolean(true,false):Required",password:String(32):Required,enablePassword:String(32),passwordType:String(256):Required,UserIdentityGroup:String(256)
USER LINE:
krejci,"Vaclav Krejci, Techsupport",false,,false,true,false,,,Internal Users,All Groups:CDT-users:CDT-technical
FOCUS:
--- false,********,,Internal Users ---
******** here is missing String "password:String(32):Required".
Any idea? How to export user and password?
Thanks for your help.
Hrosik1985
I attach log. It is during import:
2015-05-19 19:50:56: Record number: 1, Internal User krejci: Import Failed
Missing mandatory attribute in record number 5, field number 8
-------- Summary --------
Total Number of Records Processed:212
Number of Records Failed:212
Number of Records Imported:0
---------- End ----------
Hi there, just wondering if you ever found a resolution to this problem?
I had several problems.
First:
In users descriptions was incorrect characters. There can not be characters like punctuation (ěščřžýáíé), comma (because it is a separator in CSV export), exclamation mark, etc.
example:
Users and Identitty Stores -> Users -> Description
we use: name/company/contact/additional information
wrong is: Karel Novák, Company, tel.: 123 456 789, !!! Do not deactivate !!!
must be: Karel Novak / Company / 123 456 789 / Do not deactivate
The same problem is in the description of Identity Groups.
Second:
In version 5.2 was weak password policy. In version 5.6 is stronger password policy. Users who did not have adequate password, he can not be activated.
System administration -> Users -> Authentication Settings -> Password Complexity
we use: 6 characters minimum length and no additional requirements (password 123456 is OK)
new version have default: 8 characters minimum length
Solution
I corrected manually all descriptions (users, group, ACL etc.)
A user with poor password is disable. I must change user password when he calls me.
I have problem witch HA mode. That is problem in error: Registration failed due to invalid Certificate. I must disable "Enable Nodes Trust Communication" in System Administration >  Configuration >  Global System Options >  Trust Communication Settings
