two factor authentication for fwsm using RSA Tokenserver
saddam riyaz
I am currently trying to configure FWSM to have two factor authentication using RSA. I have configured the ACS and RSA server and everything is ok for routers and switches. What do I need to configure on the firewall side. I have pointed the authentication to the ACS server and a normal user with local database is able to login but when I login with a user having database with RSA , it doesnt work.
Jatin Katyal
Hope you can asnwer the below listed questions:
1.] ACS version
2.] Do you see any error on the ACS side while authenticating from RSA database.
3.] Please post the show run from the FWSM.
On the FWSM, you just need to define ACS as an authentication server.
Jatin Katyal
- Do rate helpful posts -
~Jatin
saddam riyaz
1.] ACS version 4.2
2.] Do you see any error on the ACS side while authenticating from RSA database.invalid secondary authentication credentials
On the FWSM, you just need to define ACS as an authentication server.acs server is defined , cant give out configs
NP.
Where did you see that error on the ACS? Did you check inside the reports and activities > failed attempts > "........."
Also, any logs/error on the RSA manager that we can look at?
Jatin Katyal
~Jatin
