UCP over ACS Solution Engine
omarept
Community Member
Hi List, we've adquired a new ACS v4.1 Solution Engine, before we used UCP, with ACS 3.2 Windows based. Can I enable UCP over ACS Solution Engine? is it possible? or maybe I have to use a diferent server...
Thanks...!
Omar
8 Replies 8
Jagdeep Gambhir
Level 11
Level 11
Omar,
UCP can't be installed on Appliance, you need to have another server. AS ACS SE is build on
a hardend Windows OS, and is not accessible as a normal Windows OS server.
If we want to use UCP, we need to install UCP on a seprate Windows server, which has IIS
server running.
Jagdeep
I agree with Jagdeep
Also would recomend checking the following link for UCP:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/ucp41/ucp.htm
omarept
Community Member
Thank you for your response, but at this moment a Windows Server is impossible for me (reason: money) other possibilities? Apache/Linux?
I have made it to run on Apache server, though only tested with HTTP, not HTTPS. But I know this for sure that it works with Apache.
Instructions will be same as for IIS, just make sure that you give enough privileges on "securecgi-bin" folder so that it can execute the scripts.
Have done this long way back. But yes this works.
Its worth a shot.
Prem
Hi ,
I have cisco ACS 1113 ,i have made windows vista desktop with IIS 7 ,i have configured iis ,given required privilege to securecgi-bin but still,'secure-bin' is not executing ,...i will be thankful if any one help me...thxxx
IIS 7 is not tested with UCP, so it may/may not run properly. And it has not been tested with vista desktop.
To make it run, please ensure that you have following requirements fulfilled ,
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/ucp41/ucp.htm#wp1041168
To install UCP, you must have a web server that runs either:
?Microsoft IIS 5.0 (included with Windows 2000)
?Microsoft IIS 6.0 (included with Windows Server 2003)
Prem
Thax ...
FYI,
So if you face any issues with operation of UCP on Apache, TAC may not be able to help.
But we are here, so lets try our best 🙂
Cheers,
Prem
