Unstable ACS and AD connectivity when client connecting to wireless
mjmontemayor
I have ACS 5.3 associated with Windows 2008 R2 Active Directory. I have no issue in associating both services, but when the client is trying to connect to the wireless network, the ACS connectivity with the AD flapped when I tried to ping the AD server while connecting to the wireless. It just keep prompting the credentials to connect to the wireless but no success. Base on the logs from the ACS, the Active Directory is unreacheable. I did the test connectivity from the ACS, it says connection test was succeeded. The connectivity issues only occurs when users trying to connect to newly setup wireless nertwork. We have another set up with same configuration but using ACS 5.1, which is currently on production network with no issue encountered.
Did anyone encountered this issues? Please help.
regards,
MiKe
regards, MiKe
Yes there are a few bugs that are mentioned in the release notes -
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.3/release/notes/acs_53_rn.html#wp223113
However I recommend you upgrade to the latest patch, the release notes will have steps on how to install the patch as well.
Tarik Admani
*Please rate helpful posts*
Tarik Admani
Check the acs release notes patch 3 included some major bug fixes. Are you running any patches on your acs?
Sent from Cisco Technical Support Android App
mjmontemayor
Hi, I am running out of the box OS. I have not apply any patches yet. Is this a known issues in 5.3? Thanks
regards, MiKe
Tarik Admani
Sorry for the late response. I did the installation of patch and it works.
Thanks for your help.
regards, MiKe
