Using ACS for WLAN and VPN access
cjkelly
I am using my ACS v.3 to authenticate our Wireless LAN users. I also want to use the ACS box to authenticate VPN users coming in over a 3000 box.
The problem is the accounts keep being authenticated by the WLAN group first. Is there a way to assign a user to a group based on which AAA clinet theny come from - as in send 3000 users to the pptp group and send WLAN users (coming from AP's) to the WLAN group.
I have alterted the order in external DB authentication but it made no difference
Thansk
r-simpson
Level 3
Level 3
The following URL should help you configure the user groups the way that you are trying to get it set up. http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt30/user/g.htm
