Using Base licenses from existing deployment for separate standalone guest deployment
aniiyer
Team,
A customer has an existing ISE deployment with 1000 base licenses. They have now decided to deploy another dedicated ISE instance for guest wireless access and would like to reassign around 200 base licenses from the original deployment. Is that possible and what would be the process to do so?
Anirudh Iyer
paul
Level 10
Level 10
The should be converting both deployments to Smart Licensing and they the licenses are pulled from a central pool.  Contact licensing@cisco.com for help in converting their traditional licenses into Smart Licenses.
