Using external radius with ise for guest authentication
jan.nielsen
Level 11
Level 11
Hi Everyone,
I am trying to migrate from NAC Guest Server to Cisco ISE Guest CWA on wireless, and can't figure out whether what i am trying is just unsupported or i just can't find out how to do this ?
I am attempting to authenticate my existing guest users, using a radius lookup towards my existing NAC Guest server, which has many hundred guest users with long account duration, which i really don't want to recreate on ISE, and send new passwords to all those users. Problem is i can't export the user list from NAC guest server with the password intact, and ISE can't import guest users with a set password.
Any ideas ?
Richard Atkin
Level 10
Level 10
Setup Proxy-RADIUS between the two?
Jatin Katyal
Hi Jan,
I understand what problem you're going through. There is a way to export users from the NAC Guest server; however it does not help us to import the users information with existing password. Richard suggested you the right thing to setup ISE as a RADIUS proxy server that will proxy the requests from a Network Access Device (NAD) to a RADIUS server  NAC Guest Server (NGS).
Defining an External RADIUS Server (Proxy service)
http://www.cisco.com/en/US/docs/security/ise/1.1.1/user_guide/ise_auth_pol.html#wp1127216
Jatin Katyal
- Do rate helpful posts -
~Jatin
Venkatesh Attuluri
Setting up ISE as radius  proxy server will work because NAC guest user does not support exporting user information with passwords
Step 1 Choose Administration > Network Resources > External RADIUS Servers.
The External RADIUS Servers page appears.
Step 2 Click Filter > Advanced Filter to perform your search. The Filter page appears.
Step 3 You must define whether the search should match any or all of the rules that you define on this page.
Step 4 Enter your search criteria based on the name or description of the RADIUS server, choose an operator, and enter the value.
Step 5 You can do the following:
•To add a filter condition, click the plus sign (+).
•To remove a filter condition, click the minus sign (-).
•To clear all filter conditions, click Clear Filter.
Step 6 Click Go to perform your search.
You can also save the filter criteria so that it can be used again. Click the Save icon to save the filter condition.
