Web authentication and ACL on a Cisco switch
aron.bernasconi
I configured web authentication on a 2960S-24TS-L switch in a network where the Radius is a MS Network Policy Server.
My configuration works fine if I the switch runs IOS 12.2(55)SE2, but as soon as I upgrade it to version 15.0(2)SE4 I have the following problem :
When I connect a device to the "service port" (in my config gi 1/0/24), I get the web authentication page and after filling the right credentials, the ACL applied to the port is removed. But if I disconnect the device, the ACL is no more applied to the port. When I re-connect the device a can reach all the network even if the http traffic is redirected to the auth-proxy of the switch.
The following is a part of my configuration :
ip admission name webauth1 proxy http
ip device tracking
ip access-list extended pre-webauth1
  permit udp any any eq bootps
  permit udp any any eq domain
  deny ip any any
fallback profile webauth1-profile
  ip access-group pre-webauth1 in
  ip admission webauth1
int gi 1/0/24
  authentication port-control auto
  authentication fallback webauth1-profile
blenka
Level 3
Level 3
please try these commands using your acl made.
Enable IOS http servers for web auth
ip http server
ip http secure-server
ip access-list extended ACL-WEBAUTH-REDIRECT
permit tcp any any eq www
permit tcp any any eq 443
deny ip any any
