What FMC and ISE versions are supported to RTC using pxGrid?
victguti
I have seen in the past that RTC through the integration of FMC v5.4 and ISE 1.3 using pxGrid is supported.
I would like to know what other pairs of FMC version and ISE version are supported nowadays.
Víctor.
hslai
See Integrated Product Compatibility from our FirePower team.
In our lab, How To: Rapid Threat Containment (RTC) with Cisco FireSIGHT and ISE is working ok with FMC 5.4 and either ISE 2.0, or 2.1, as well.
hslai
