What is difference of where to put ip address in between group-policy and tunnel-group in SSL vpn ?
wfqk
Level 5
Level 5
Dear All
I reviewed several SSL VPN configuration examples. After setting up ip local pool for the ssl vpn users, some example's configuration put it under the group-policy, while other put it under the tunnel-group. My question is what is difference between the two configuration ?
Thank you
jan.nielsen
Level 7
Level 7
One reason for doing that, could be to assign from different ip pools, depending on what group-policy your users land in, which could be assigned dynamically by an authentication server based on AD group membership.
Thank you for your reply. Can you tell a little more about this ? Thank you again
