Showing results forĀ
Search instead forĀ
Did you mean:Ā
What to do when a Primary ACS appliance fails within a Split ACS 5.6 deployment?
3iron
Hi All,
Could anyone offer advice on this scenario?
Environment: 2 x ACS 5.6 appliances
- Primary ACS Appliance (+Log collector)
- Secondary ACS Appliance
Test process
1. Simulated network connection failure on Primary appliance
2. Test switch able to authenticate against Secondary appliance
3. Able to login to Secondary - Read only, no administration function, unable to view logs as log collector also
If administration required what is the best option for the secondary appliance?
- Promote to primary?
- Request local mode?
3iron
Over a year later i'm g00gle searching for the same thing and come across my post from last year haha!
Reading through the cisco doc it explains what the functionality does - but not when, i.e. scenario basis. If anyone is able to offer advice / previous experience on this scenario it would be very much appreciated!
Ok after some searching I found cisco doc with a scenario reference:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-6/user/guide/acsuserguide/admin_operations.html#75607
Scenario covered in failover section
"ACS 5.6 allows you to configure multiple ACS instances for a deployment scenario. Each deployment can have one primary and multiple secondary ACS servers.
Scenario: Primary ACS goes down in a Distributed deployment"
Hi Davies,
If primary goes down ,then we can promote any secondary server to primary .
Once promotion is completed ,then change the log collector to another server to see the logs .
Please let us know ,if you have any queries .
VenkataKrishna
Please rate helpful posts and mark correct answers.
