Why split Pri MnT and Pri PAN in design
bobcat
Hi Everyone,
I often find the following node design in documents or some discussion threads:
Node A: Pri MnT and Sec PAN
Node B: Sec MnT and Pri PAN
This appears in the Cisco Document but without explanation:
(https://www.cisco.com/c/en/us/td/docs/security/ise/3-1/install_guide/b_ise_InstallationGuide31/b_ise_InstallationGuide31_chapter_1.html)
Please help explain why this is used? I can't come up with any benefits in terms of workload distribution or replication or HA.
Thank you in advance.
Damien Miller
I actually don't agree with the diagram. I think having the primary share the same node or same DC in larger deployments is optimal. I've been using primary PAN/MnT on the same node/DC for a few years now. Craig explained why this would be optimal.
https://community.cisco.com/t5/network-access-control/ise-2-node-deployment-monitoring-role-question/m-p/3547947/highlight/true#M509137
"Technically, there is no mandate set as to which nodes are primary in a standalone or hybrid deployment model. The reason why I recommend the consolidation of Primary PAN, MNT and optionally pxGrid on same node is the fact that the MnT node is always processing the same logs whether primary or secondary.  Furthermore, the operational data and reports displayed by PAN are fetched from Active MnT, which when collocated, are local to PAN.  And finally, the Active PAN and MNT publish to the active pxGrid controller, which again would also be local.
In many cases, the redundant PAN+MNT nodes may be in different locations.  Especially for these cases, you would want to avoid the delay between nodes.  It also makes the HA design a bit more intuitive to have all services active on same node.
So although at a high level it may seem like a good idea to split active role for PAN, MNT and PXG across personas, I have yet to come across sufficient justification to do so, and actually came across an escalation where customer had issues until they consolidated active PAN and MNT on same node in a dual datacenter setup."
5 Replies 5
balaji.bandi
Same Document explain little bit of split deployment.
If you Make Primary MNT and Pan both same appliance, there is no work load balance here, so for better utilisation of compute syustem above design give you flexliblity to split the load different nodes, and failover for high availability.
BB
Thanks for the explanation. I see, if for splitting the computing workload between primary MnT and PAN, that's one reason. But I think there should not be any differences in terms of HA, right?
The PSN will send operational data to both primary and secondary MnT, the Primary Mnt will replicate data to Secondary MnT, and the Primary PAN can retrieve data from the secondary MnT immediately.
So, there should not be any data loss even you put Pri PAN and Pri MnT in one node.
Sure agreed with @Damien Miller  post.ahead of my reply much appriciated input.
BB
Damien Miller
Thanks Damien. Yes, Craig's explanation makes sense esp. the secondary nodes often put on a DR site.
Thanks for the quote and the reply!
