Wired 802.1X issue
Hi folks,
I am having an issue working with MAB , 8021.X switch 2960 & ClearPass.
Each time a connect ip phone & PC the interface goes to err-disable state even if I do noy have port security configured on the switch.
*Apr 25 03:54:46.536: AUTH-EVENT (Fa0/12) Authorized client count: 0
*Apr 25 03:54:55.814: %DOT1X-5-FAIL: Authentication failed for client (a048.1c7c.8643) on Interface Fa0/12 AuditSessionID 0AC8C83C000004351C14B60F
*Apr 25 03:54:55.814: AUTH-EVENT (Fa0/12) Received 'AUTHC_RESULT', current method is dot1x (handle 0xC0000436)
*Apr 25 03:54:55.814: AUTH-EVENT (Fa0/12) Authc Result: no-response
*Apr 25 03:54:55.814: AUTH-EVENT (Fa0/12) Client a048.1c7c.8643, Method dot1x changing state from 'Running' to 'Authc Failed'
*Apr 25 03:54:55.814: AUTH-EVENT (Fa0/12) Client a048.1c7c.8643, Context changing state from 'Running' to 'Authc Failed'
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 15.0(2)SE11
hslai
balaji.bandi
Can you explain and show us the configuration :
"Each time a connect ip phone & PC the interface goes to err-disable state even if I do noy have port security configured on the switch. "
The Logs show Devices trying  to authenticatte, so we need to look the configure to confirm.
or you can follow other post to mitigate the issue.
BB
Mike.Cifelli
Please ensure on your switch interface configs you have configured host-mode multi-domain. Multi-domain allows a host and voice device to authenticate on the same port. HTH!
