wired 802.1x machine authentication
mschooley
Level 4
Level 4
anything extra that has to be done to have the machine authenticate. I have a machine account, I have peap for machine accounts enabled on acs 3.2. I have the check mark for use computer account when no user info available. Appears to be sending to switch, and switch sends to acs. acs then gets error remote database account restrictions. Even if it does authenticate, how would I assign it to a vlan since I can't put machine accounts into a group to match my acs groups, unless I use the default group.
nikhil_m
Level 6
Level 6
Looks like you gotta restart your acs!!
Nikh.
