Wired CWA with ISE 2.x and 2960X switch 15.2
kidvelvet
Level 4
Level 4
I have setup for a customer a wireless Centralized Web Authentication portal that uses AD authentication in order to access the proper network resources (customer does not want to use a dot1x client, so we are going the web auth route). This has worked as expected, and now we are just putting some finishing touches on the configuration to get the workflow just right.
However, when I try the same thing on the wired side with a 2960X using 15.2.2 code, I seem to get all the MAB authentication to work properly, the switch gets the correct guest redirect URL and ACL, and I am able to connect to the https://guest.example.net:8443/portal<redacted> site when entered manually, but going to 80 or 443 will not cause a redirection.
Here is the relevant switch configuration:
service password-encryption
hostname <switch>
boot-start-marker
boot-end-marker
logging buffered 65500
enable secret <redacted>
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication dot1x default group radius
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
aaa accounting system default start-stop group radius
aaa server radius dynamic-author
client 192.168.25.7 server-key <redacted>
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring
switch 1 provision ws-c2960x-48lps-l
device-sensor accounting
device-sensor notify all-changes
ip dhcp snooping
ip domain-name int.example.com
ip name-server 192.168.24.5
authentication mac-move permit
epm logging
dot1x system-auth-control
dot1x critical eapol
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
lldp run
interface GigabitEthernet1/0/19
description Open Office Port
switchport access vlan 25
switchport mode access
ip access-group ACL_DEFAULT in
duplex full
authentication host-mode multi-auth
authentication order mab
authentication priority mab
authentication port-control auto
authentication timer reauthenticate server
authentication violation restrict
mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
spanning-tree portfast
interface Vlan1
no ip address
no ip route-cache
interface Vlan24
ip address 192.168.24.2 255.255.255.0
no ip redirects
no ip proxy-arp
no ip route-cache
ip default-gateway 192.168.24.1
ip http server
ip http secure-server
ip ssh version 2
ip access-list extended ACL_DEFAULT
permit udp any eq bootpc any eq bootps
permit udp any any eq domain
permit icmp any any
permit udp any any eq tftp
permit ip any host 192.168.25.7
deny   ip any any
ip access-list extended GUESTREDIRECT
deny   udp any eq bootpc any eq bootps
deny   udp any any eq domain
deny   ip any host 192.168.25.7
permit tcp any any eq www
permit tcp any any eq 443
deny   ip any any
ip radius source-interface Vlan25
logging origin-id ip
logging source-interface Vlan24
logging host 192.168.25.7 transport udp port 20514
access-list 10 permit 192.168.25.0 0.0.0.255
access-list 10 deny   any log
snmp-server community <redacted> RO 10
snmp-server trap-source Vlan24
snmp-server enable traps snmp linkdown linkup
snmp-server enable traps mac-notification change move threshold
snmp-server host 192.168.25.7 version 2c way2l84U  mac-notification snmp
tacacs server TACACS
address ipv4 192.168.25.7
key <redacted>
radius-server attribute 6 on-for-login-auth
radius-server attribute 6 support-multiple
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius server RADIUS
address ipv4 192.168.25.7 auth-port 1812 acct-port 1813
key <redacted>
line con 0
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
ntp server pool.ntp.org
mac address-table notification change
mac address-table notification mac-move
end
<switch>#
And here are the logs with debugging turned on for MAB, EPM, and RADIUS, along with the sh auth sess int g1/0/19 det
Feb  7 23:07:59.303: RADIUS/ENCODE(00000000):Orig. component type = Invalid
Feb  7 23:07:59.303: RADIUS(00000000): Config NAS IP: 0.0.0.0
Feb  7 23:07:59.303: RADIUS(00000000): Config NAS IPv6: ::
Feb  7 23:07:59.303: RADIUS(00000000): sending
Feb  7 23:07:59.303: mab-sm: Received event 'MAB_DELETE' on handle 0xEE000010
Feb  7 23:07:59.303: mab-ev: Received ABORT event from Auth Mgr for 0xEE000010 (d8d3.8530.ad7c)
Feb  7 23:07:59.303: mab-ev: Deleted credentials profile for 0xEE000010 (dot1x_mac_auth_d8d3.8530.ad7c)
Feb  7 23:07:59.303: mab-ev: Freed MAB client context
Feb  7 23:07:59.307: RADIUS/ENCODE: Best Local IP-Address 192.168.24.2 for Radius-Server 192.168.25.7
Feb  7 23:07:59.307: RADIUS(00000000): Send Accounting-Request to 192.168.25.7:1813 onvrf(0) id 1646/54, len 308
Feb  7 23:07:59.307: RADIUS:  authenticator 92 2C FF 4A E6 FB 25 3E - 07 E3 FF 66 C3 A6 BF 08
Feb  7 23:07:59.310: RADIUS:  Framed-IP-Address   [8]   6   192.168.25.175
Feb  7 23:07:59.310: RADIUS:  User-Name           [1]   19  "D8-D3-85-30-AD-7C"
Feb  7 23:07:59.310: RADIUS:  Vendor, Cisco       [26]  49
Feb  7 23:07:59.310: RADIUS:   Cisco AVpair       [1]   43  "audit-session-id=C0A818020000002C01F1CE73"
Feb  7 23:07:59.310: RADIUS:  Vendor, Cisco       [26]  18
Feb  7 23:07:59.310: RADIUS:   Cisco AVpair       [1]   12  "method=mab"
Feb  7 23:07:59.310: RADIUS:  Called-Station-Id   [30]  19  "00-41-D2-ED-43-13"
Feb  7 23:07:59.310: RADIUS:  Calling-Station-Id  [31]  19  "D8-D3-85-30-AD-7C"
Feb  7 23:07:59.310: RADIUS:  NAS-IP-Address      [4]   6   192.168.24.2
Feb  7 23:07:59.310: RADIUS:  NAS-Port-Id         [87]  23  "GigabitEthernet1/0/19"
Feb  7 23:07:59.310: RADIUS:  NAS-Port-Type       [61]  6   Ethernet                  [15]
Feb  7 23:07:59.310: RADIUS:  NAS-Port            [5]   6   50119
Feb  7 23:07:59.310: RADIUS:  Acct-Session-Id     [44]  10  "00000020"
Feb  7 23:07:59.310: RADIUS:  Acct-Terminate-Cause[49]  6   lost-carrier              [2]
Feb  7 23:07:59.310: RADIUS:  Class               [25]  53
Feb  7 23:07:59.310: RADIUS:   43 41 43 53 3A 43 30 41 38 31 38 30 32 30 30 30  [CACS:C0A81802000]
Feb  7 23:07:59.310: RADIUS:   30 30 30 32 43 30 31 46 31 43 45 37 33 3A 69 73  [0002C01F1CE73:is]
Feb  7 23:07:59.310: RADIUS:   65 30 31 2F 32 37 35 35 35 37 34 33 34 2F 31 32  [e01/275557434/12]
Feb  7 23:07:59.310: RADIUS:   36 37 36               [ 676]
Feb  7 23:07:59.310: RADIUS:  Acct-Status-Type    [40]  6   Stop                      [2]
Feb  7 23:07:59.310: RADIUS:  Event-Timestamp     [55]  6   1486508879
Feb  7 23:07:59.310: RADIUS:  Acct-Session-Time   [46]  6   368
Feb  7 23:07:59.310: RADIUS:  Acct-Input-Octets   [42]  6   253119112
Feb  7 23:07:59.310: RADIUS:  Acct-Output-Octets  [43]  6   1984353927
Feb  7 23:07:59.310: RADIUS:  Acct-Input-Packets  [47]  6   743075
Feb  7 23:07:59.310: RADIUS:  Acct-Output-Packets [48]  6   1570299
Feb  7 23:07:59.310: RADIUS:  Acct-Delay-Time     [41]  6   0
Feb  7 23:07:59.310: RADIUS(00000000): Sending a IPv4 Radius Packet
Feb  7 23:07:59.314: RADIUS(00000000): Started 5 sec timeout
Feb  7 23:07:59.321: RADIUS: Received from id 1646/54 192.168.25.7:1813, Accounting-response, len 20
Feb  7 23:07:59.321: RADIUS:  authenticator 1D E3 B6 9C BA 36 73 65 - CD 3D 43 10 E7 CF A3 A3
Feb  7 23:08:01.278: %LINK-5-CHANGED: Interface GigabitEthernet1/0/19, changed state to administratively down
Feb  7 23:08:02.281: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/19, changed state to down
Feb  7 23:08:06.395: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/19, changed state to down
Feb  7 23:08:08.202: %SYS-5-CONFIG_I: Configured from console by <user> on vty0 (192.168.25.179)
Feb  7 23:08:09.146: mab-ev: [d8d3.8530.ad7c, Gi1/0/19] Received MAB context create from AuthMgr
Feb  7 23:08:09.146: mab-ev: MAB authorizing d8d3.8530.ad7c
Feb  7 23:08:09.146: mab-ev: Created MAB client context 0xAF000011
Feb  7 23:08:09.146:     mab : initial state mab_initialize has enter
Feb  7 23:08:09.146: mab-ev: [d8d3.8530.ad7c, Gi1/0/19] Sending create new context event to EAP from MAB for 0xAF000011 (d8d3.8530.ad7c)
Feb  7 23:08:09.146: mab-ev: [d8d3.8530.ad7c, Gi1/0/19] MAB authentication started for 0x07FE3D28 (d8d3.8530.ad7c)
Feb  7 23:08:09.146: mab-ev: [d8d3.8530.ad7c, Gi1/0/19] Invalid EVT 9 from EAP
Feb  7 23:08:09.146: mab-sm: [d8d3.8530.ad7c, Gi1/0/19] Received event 'MAB_CONTINUE' on handle 0xAF000011
Feb  7 23:08:09.150:     mab : during state mab_initialize, got event 1(mabContinue)
Feb  7 23:08:09.150: @@@ mab : mab_initialize -> mab_authorizing
Feb  7 23:08:09.150: mab-ev: [d8d3.8530.ad7c] formatted mac = d8d38530ad7c
Feb  7 23:08:09.150: mab-ev: [d8d3.8530.ad7c] created mab pseudo dot1x profile dot1x_mac_auth_d8d3.8530.ad7c
Feb  7 23:08:09.150: mab-ev: [d8d3.8530.ad7c, Gi1/0/19] Starting MAC-AUTH-BYPASS for 0xAF000011 (d8d3.8530.ad7c)
Feb  7 23:08:09.150: mab-ev: [d8d3.8530.ad7c, Gi1/0/19] Invalid EVT 9 from EAP
Feb  7 23:08:09.150: RADIUS/ENCODE(00000000):Orig. component type = Invalid
Feb  7 23:08:09.150: RADIUS(00000000): Config NAS IP: 0.0.0.0
Feb  7 23:08:09.150: RADIUS(00000000): Config NAS IPv6: ::
Feb  7 23:08:09.150: RADIUS(00000000): sending
Feb  7 23:08:09.150: RADIUS/ENCODE: Best Local IP-Address 192.168.24.2 for Radius-Server 192.168.25.7
Feb  7 23:08:09.150: RADIUS(00000000): Send Access-Request to 192.168.25.7:1812 onvrf(0) id 1645/18, len 267
Feb  7 23:08:09.153: RADIUS:  authenticator 25 3B 90 7C 69 B9 43 8D - 03 D8 76 55 31 62 55 12
Feb  7 23:08:09.153: RADIUS:  User-Name           [1]   14  "d8d38530ad7c"
Feb  7 23:08:09.153: RADIUS:  User-Password       [2]   18  *
Feb  7 23:08:09.153: RADIUS:  Service-Type        [6]   6   Call Check                [10]
Feb  7 23:08:09.153: RADIUS:  Vendor, Cisco       [26]  31
Feb  7 23:08:09.153: RADIUS:   Cisco AVpair       [1]   25  "service-type=Call Check"
Feb  7 23:08:09.153: RADIUS:  Framed-MTU          [12]  6   1500
Feb  7 23:08:09.153: RADIUS:  Called-Station-Id   [30]  19  "00-41-D2-ED-43-13"
Feb  7 23:08:09.153: RADIUS:  Calling-Station-Id  [31]  19  "D8-D3-85-30-AD-7C"
Feb  7 23:08:09.153: RADIUS:  Message-Authenticato[80]  18
Feb  7 23:08:09.153: RADIUS:   BB 19 3E D4 E1 28 1C 11 6B C3 CB E4 98 8E D9 9E               [ >(k]
Feb  7 23:08:09.153: RADIUS:  EAP-Key-Name        [102] 2   *
Feb  7 23:08:09.153: RADIUS:  Vendor, Cisco       [26]  49
Feb  7 23:08:09.153: RADIUS:   Cisco AVpair       [1]   43  "audit-session-id=C0A818020000002D01F799E6"
Feb  7 23:08:09.153: RADIUS:  Vendor, Cisco       [26]  18
Feb  7 23:08:09.153: RADIUS:   Cisco AVpair       [1]   12  "method=mab"
Feb  7 23:08:09.153: RADIUS:  Framed-IP-Address   [8]   6   192.168.25.175
Feb  7 23:08:09.153: RADIUS:  NAS-IP-Address      [4]   6   192.168.24.2
Feb  7 23:08:09.153: RADIUS:  NAS-Port-Id         [87]  23  "GigabitEthernet1/0/19"
Feb  7 23:08:09.153: RADIUS:  NAS-Port-Type       [61]  6   Ethernet                  [15]
Feb  7 23:08:09.153: RADIUS:  NAS-Port            [5]   6   50119
Feb  7 23:08:09.153: RADIUS(00000000): Sending a IPv4 Radius Packet
Feb  7 23:08:09.153: RADIUS(00000000): Started 5 sec timeout
Feb  7 23:08:09.185: RADIUS: Received from id 1645/18 192.168.25.7:1812, Access-Accept, len 427
Feb  7 23:08:09.185: RADIUS:  authenticator 3F FA C4 0C EC B2 98 E3 - C6 07 B5 56 9C F1 EB 5D
Feb  7 23:08:09.185: RADIUS:  User-Name           [1]   19  "D8-D3-85-30-AD-7C"
Feb  7 23:08:09.185: RADIUS:  State               [24]  40
Feb  7 23:08:09.185: RADIUS:   52 65 61 75 74 68 53 65 73 73 69 6F 6E 3A 43 30  [ReauthSession:C0]
Feb  7 23:08:09.188: RADIUS:   41 38 31 38 30 32 30 30 30 30 30 30 32 44 30 31  [A818020000002D01]
Feb  7 23:08:09.188: RADIUS:   46 37 39 39 45 36            [ F799E6]
Feb  7 23:08:09.188: RADIUS:  Class               [25]  53
Feb  7 23:08:09.188: RADIUS:   43 41 43 53 3A 43 30 41 38 31 38 30 32 30 30 30  [CACS:C0A81802000]
Feb  7 23:08:09.188: RADIUS:   30 30 30 32 44 30 31 46 37 39 39 45 36 3A 69 73  [0002D01F799E6:is]
Feb  7 23:08:09.188: RADIUS:   65 30 31 2F 32 37 35 35 35 37 34 33 34 2F 31 32  [e01/275557434/12]
Feb  7 23:08:09.188: RADIUS:   36 38 37               [ 687]
Feb  7 23:08:09.188: RADIUS:  Message-Authenticato[80]  18
Feb  7 23:08:09.188: RADIUS:   09 28 1D 2D F3 B0 F0 A3 EC 35 B4 71 EF CF 30 59            [ (-5q0Y]
Feb  7 23:08:09.188: RADIUS:  Vendor, Cisco       [26]  38
Feb  7 23:08:09.188: RADIUS:   Cisco AVpair       [1]   32  "url-redirect-acl=GUESTREDIRECT"
Feb  7 23:08:09.188: RADIUS:  Vendor, Cisco       [26]  197
Feb  7 23:08:09.188: RADIUS:   Cisco AVpair       [1]   191 "url-redirect=https://guest.example.com:8443/portal/gateway?sessionId=C0A818020000002D01F799E6&portal=1c252db0-eaa9-11e6-822a-005056a009c4&action=cwa&token=1ec40fb7c5b511904c0dd95011d0c4d8"
Feb  7 23:08:09.188: RADIUS:  Vendor, Cisco       [26]  42
Feb  7 23:08:09.188: RADIUS:   Cisco AVpair       [1]   36  "profile-name=Microsoft-Workstation"
Feb  7 23:08:09.188: RADIUS(00000000): Received from id 1645/18
Feb  7 23:08:09.188: RADIUS/DECODE: parse unknown cisco vsa "profile-name" - IGNORE
Feb  7 23:08:09.191: mab-ev: [d8d3.8530.ad7c, Gi1/0/19] MAB received an Access-Accept for 0xAF000011 (d8d3.8530.ad7c)
Feb  7 23:08:09.191: mab-sm: [d8d3.8530.ad7c, Gi1/0/19] Received event 'MAB_RESULT' on handle 0xAF000011
Feb  7 23:08:09.191:     mab : during state mab_authorizing, got event 5(mabResult)
Feb  7 23:08:09.191: @@@ mab : mab_authorizing -> mab_terminate
Feb  7 23:08:09.191: mab-ev: [d8d3.8530.ad7c, Gi1/0/19] Deleted credentials profile for 0xAF000011 (dot1x_mac_auth_d8d3.8530.ad7c)
Feb  7 23:08:09.195: %EPM-6-POLICY_REQ: IP 192.168.25.175| MAC d8d3.8530.ad7c| AuditSessionID C0A818020000002D01F799E6| EVENT APPLY
Feb  7 23:08:09.195: %EPM-6-POLICY_APP_SUCCESS: Policy Application succeded for Client [192.168.25.175] MAC [d8d3.8530.ad7c] AuditSession ID [C0A818020000002D01F799E6] for POLICY_TYPE [URL Redirect] POLICY_NAME [https://guest.example.com:8443/portal/gateway?sessionId=C0A818020000002D01F799E6&portal=1c252db0-eaa9-11e6-822a-005056a009c4&action=cwa&token=1ec40fb7c5b511904c0dd95011d0c4d8]
Feb  7 23:08:10.226: RADIUS/ENCODE(00000000):Orig. component type = Invalid
Feb  7 23:08:10.226: RADIUS(00000000): Config NAS IP: 0.0.0.0
Feb  7 23:08:10.226: RADIUS(00000000): Config NAS IPv6: ::
Feb  7 23:08:10.226: RADIUS(00000000): sending
Feb  7 23:08:10.226: RADIUS/ENCODE: Best Local IP-Address 192.168.24.2 for Radius-Server 192.168.25.7
Feb  7 23:08:10.226: RADIUS(00000000): Send Accounting-Request to 192.168.25.7:1813 onvrf(0) id 1646/55, len 272
Feb  7 23:08:10.226: RADIUS:  authenticator D8 BF 66 8B B0 00 96 9D - 1C 46 24 B7 45 05 48 FD
Feb  7 23:08:10.226: RADIUS:  Framed-IP-Address   [8]   6   192.168.25.175
Feb  7 23:08:10.226: RADIUS:  User-Name           [1]   19  "D8-D3-85-30-AD-7C"
Feb  7 23:08:10.230: RADIUS:  Vendor, Cisco       [26]  49
Feb  7 23:08:10.230: RADIUS:   Cisco AVpair       [1]   43  "audit-session-id=C0A818020000002D01F799E6"
Feb  7 23:08:10.230: RADIUS:  Vendor, Cisco       [26]  18
Feb  7 23:08:10.230: RADIUS:   Cisco AVpair       [1]   12  "method=mab"
Feb  7 23:08:10.230: RADIUS:  Called-Station-Id   [30]  19  "00-41-D2-ED-43-13"
Feb  7 23:08:10.230: RADIUS:  Calling-Station-Id  [31]  19  "D8-D3-85-30-AD-7C"
Feb  7 23:08:10.230: RADIUS:  NAS-IP-Address      [4]   6   192.168.24.2
Feb  7 23:08:10.230: RADIUS:  NAS-Port-Id         [87]  23  "GigabitEthernet1/0/19"
Feb  7 23:08:10.230: RADIUS:  NAS-Port-Type       [61]  6   Ethernet                  [15]
Feb  7 23:08:10.230: RADIUS:  NAS-Port            [5]   6   50119
Feb  7 23:08:10.230: RADIUS:  Acct-Session-Id     [44]  10  "00000021"
Feb  7 23:08:10.230: RADIUS:  Class               [25]  53
Feb  7 23:08:10.230: RADIUS:   43 41 43 53 3A 43 30 41 38 31 38 30 32 30 30 30  [CACS:C0A81802000]
Feb  7 23:08:10.230: RADIUS:   30 30 30 32 44 30 31 46 37 39 39 45 36 3A 69 73  [0002D01F799E6:is]
Feb  7 23:08:10.230: RADIUS:   65 30 31 2F 32 37 35 35 35 37 34 33 34 2F 31 32  [e01/275557434/12]
Feb  7 23:08:10.230: RADIUS:   36 38 37               [ 687]
Feb  7 23:08:10.230: RADIUS:  Acct-Status-Type    [40]  6   Start                     [1]
Feb  7 23:08:10.230: RADIUS:  Event-Timestamp     [55]  6   1486508890
Feb  7 23:08:10.230: RADIUS:  Acct-Delay-Time     [41]  6   0
Feb  7 23:08:10.230: RADIUS(00000000): Sending a IPv4 Radius Packet
Feb  7 23:08:10.230: RADIUS(00000000): Started 5 sec timeout
Feb  7 23:08:10.240: RADIUS: Received from id 1646/55 192.168.25.7:1813, Accounting-response, len 20
Feb  7 23:08:10.240: RADIUS:  authenticator 40 91 18 5B FF 80 AE 81 - 64 DA 46 23 CD 04 CE 56
<switch>#sh auth sess int g1/0/19 det
            Interface:  GigabitEthernet1/0/19
          MAC Address:  d8d3.8530.ad7c
         IPv6 Address:  Unknown
         IPv4 Address:  192.168.25.175
            User-Name:  D8-D3-85-30-AD-7C
               Status:  Authorized
               Domain:  DATA
       Oper host mode:  multi-auth
     Oper control dir:  both
      Session timeout:  N/A
      Restart timeout:  N/A
Periodic Acct timeout:  N/A
       Session Uptime:  201s
    Common Session ID:  C0A818020000002D01F799E6
      Acct Session ID:  0x00000021
               Handle:  0xD3000013
       Current Policy:  POLICY_Gi1/0/19
Local Policies:
        Service Template: DEFAULT_LINKSEC_POLICY_SHOULD_SECURE (priority 150)
Server Policies:
         URL Redirect:  https://guest.example.com:8443/portal/gateway?sessionId=C0A818020000002D01F799E6&portal=1c252db0-eaa9-11e6-822a-005056a009c4&action=cwa&token=1ec40fb7c5b511904c0dd95011d0c4d8
     URL Redirect ACL:  GUESTREDIRECT
Method status list:
       Method           State
       mab              Authc Success
<switch>#
Any ideas are appreciated. Just not sure why the redirection is not occurring on the computer.
-Steve
howon
Are you sending dACL as well? If not then I would send 'ip permit any any' dACL along. Looking at your ACL-DEFAULT, you have 'deny ip any any' which is denying any web traffic destined for IP other than ISE. sending the 'ip permit any any' should address that.
Hosuk
howon
Hosuk
