WLC and 802.1X and ISE flow
Hi Experts,
I have a question, tried to seach for the correct answer and even read some material about it, but still I dont have like a full and crystal overview of how the 802.1X works
in a lot of examples of 802.1X and , they are referencing as the 802.1X as Port Based Authentication. They always put a Cisco Switch as the intermediare device between the client and the RADIUS Server, ok, thats fine, but
I want to fully understand in a Wireless Environment with ISE as RADIUS, a WLC in the middle and several APs for connecting clients,
I want to know if the WLC is acting as the 802.1X switch in the middle or if it is the ISE?
In other words, Im quite confused cause I thought the 802.1X is configurable only in a physical switch wired connected to workstation, do you see what I'm saying?
I hear a lot of the IT guys in my work about ISE and 802.1X via wireless, but I still keep thinking that they are refering to the switch where the workstation is wired connected to the switch, but in the wireless?
Is it the WLC performing the role of 802.1X like the switch in the middle or is it the ISE server doing the 802.1X?
Im confused cause I used to think that 802.1X is when you go to the interface of the switch and put the commands and bla bla bla, but in a wireless infra, who is the 802.1X guy?
Can someone please explain me?
Marvin Rhoads
In a wireless 802.1x environment, the wireless LAN controller (WLC) is the authenticator (also known as Network Access Device or NAD by ISE).
We set the wireless 802.1x bits under the WLAN settings (mostly Security and Advanced tabs) on the WLC. That is roughly equivalent to the global and interface-specific settings we make on a switch
The ISE server is the RADIUS server - it is never the NAD.
Marvin Rhoads
nice, perfect, got it, all this start making sense Mr. Rhoads,
such a nice explanation.
