WLC keep on authenticate issue
yong khang NG
Level 7
Level 7
Hi all,
Having issue with WLC 5508 using ACS 5.2 tacacs+ protocol to do device management
The problem statement is after key in the username and password on the WLC login page, it is endlessly prompt for authentication on WLC.
Whilst on ACS monitoring and reporting i able to see it is successfully authenticated, shown at AAA protocol > TACACS+ Authentication
On ACS, the shell profile for this is setting role1 , value = ALL.
Can please suggest or any idea i can make it with priviledge to administering the WLC, thanks
The firmware setting in use as below:-
1. WLC 5508  with firmware 7.0.222.0
2. ACS version 5.2.0.26
Noel
camejia
Level 9
Level 9
I am attaching an example. I did notice that you are using "role1". Can you change it to "Role1" with capital R?
Hope this helps.
Regards.
Hi Mejia,
Thanks for the reply !!!
I do according your instruction and found tihs log from the WLC.
*emWeb: Jan 11 10:57:44.401: %EMWEB-1-LOGIN_FAILED: ews_auth.c:2105  Login failed for the user:noel. Service-Type is not present or it  doesn't allow READ/WRITE permission..
Anything i can tune on the ACS or WLC?
Please advice.
Noel
Hello Noel,
Have you confirmed on the ACS Logs that the user "noel" is hitting the appropriate Rule which assigns the Role1=ALL?
Can you shared screenshots of the ACS configuration (Shell Profile, Access Service Rule, Report Details by clicking on the magnifier)?
Will wait for your response.
Regards.
