Ansible Builtin Ping
Netmart
Level 3
Level 3
I was running the following playbook; the purpose is to run ping checks of virtual IPs on a Cisco 7K switch.
So far so good. However, when I wanted to expand the playbook by also counting the successful ping.
Running the runbook again I receive the following error:
 ansible-builtin-ping-count-pong2.yml
- name: Ansible Ping Check on Cisco IOS Virtual IPs on Cisco 7k
  hosts: 7KcoreVLANSios
  vars_files:
         - /home/cisco/Ansible/vault_password5.yml
  gather_facts: false # No need to gather facts for a simple ping
  tasks:
    - name: Ping all hosts
      ansible.builtin.ping:
      register: ping_results
    - name: Count successful pings
      ansible.builtin.set_fact:
        successful_pings_count: "{{ ping_results.results | selectattr('ping', 'equalto', 'pong') | list | length }}"
    - name: Display the count of successful pings
      ansible.builtin.debug:
        msg: "Successfully pinged {{ successful_pings_count }} hosts."
inventory
[7KcoreVLANSios]
10.0.0.1
10.0.0.2
10.0.0.3
[7KcoreVLANSios:vars]
ansible_network_os=ios
ansible_connection=network_cli
Error:
fatal: [10.254.11.1]: FAILED! => {"msg": "The task includes an option with an undefined variable.
The error was: 'dict object' has no attribute 'results'. 'dict object' has no attribute 'results'\n\n
The error appears to be in '/home/cisco/Ansible/roles/ios-xe-role/tasks/ios-xe-checks/ansible-builtin-ping-count-pong2.yml': line 15, column 7, but may\nbe elsewhere in the file depending on the exact syntax problem.\n\nThe offending line appears to be:\n\n\n    - name: Count successful pings\n      ^ here\n"}
Thank you for any advise.
@Netmart you need to update your playbook to iterate through the hosts and count the successful pings.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
