09-09-2025 04:22 PM - edited 09-09-2025 04:23 PM
I was running the following playbook; the purpose is to run ping checks of virtual IPs on a Cisco 7K switch.
So far so good. However, when I wanted to expand the playbook by also counting the successful ping.
Running the runbook again I receive the following error:
ansible-builtin-ping-count-pong2.yml
- name: Ansible Ping Check on Cisco IOS Virtual IPs on Cisco 7k
hosts: 7KcoreVLANSios
vars_files:
- /home/cisco/Ansible/vault_password5.yml
gather_facts: false # No need to gather facts for a simple ping
tasks:
- name: Ping all hosts
ansible.builtin.ping:
register: ping_results
- name: Count successful pings
ansible.builtin.set_fact:
successful_pings_count: "{{ ping_results.results | selectattr('ping', 'equalto', 'pong') | list | length }}"
- name: Display the count of successful pings
ansible.builtin.debug:
msg: "Successfully pinged {{ successful_pings_count }} hosts."
inventory
[7KcoreVLANSios]
10.0.0.1
10.0.0.2
10.0.0.3
[7KcoreVLANSios:vars]
ansible_network_os=ios
ansible_connection=network_cli
Error:
fatal: [10.254.11.1]: FAILED! => {"msg": "The task includes an option with an undefined variable.
The error was: 'dict object' has no attribute 'results'. 'dict object' has no attribute 'results'\n\n
The error appears to be in '/home/cisco/Ansible/roles/ios-xe-role/tasks/ios-xe-checks/ansible-builtin-ping-count-pong2.yml': line 15, column 7, but may\nbe elsewhere in the file depending on the exact syntax problem.\n\nThe offending line appears to be:\n\n\n - name: Count successful pings\n ^ here\n"}
Thank you for any advise.
09-10-2025 02:16 AM
@Netmart you need to update your playbook to iterate through the hosts and count the successful pings.
Hope this helps.
