Cisco CSR 1000v Deployment
saishreen
We are trying to deploy Cisco CSR 1000v.
Although we are in conversation with Azure Support Team, there seems to be one query they are not aware of.
When we create Cisco CSR 1000v 2 NIC's in Azure it creates 2 subnets.
If anyone could, we needed help with configuration of these 2 subnets, and how they will connect to our on-premise CISCO ASA device
ctm-tech
I'm going through the same thing at the moment. I've read through: https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/azu/b_csr1000config-azure/b_csr1000config-azure_chapter_011.pdf
But feel like that is out of date.
From my understanding:
You would connect to your ASA via a public IP that you assign to the VM, and then you use Azure Route Tables to control the traffic to pass to your VM.
I am running 1 vnet with 8 subnets but i think the process would be the same.
I've also put the csr into its own subnet for manageability.
