Exasock-daemon not working
ysm
When attempting to accelerate a daemon process using a k3p-s(X25) device(exasock ./daemon), it was observed that the acceleration did not take effect, as exasock-stat could not see the connection status. However, when changed to a console program, the acceleration took effect. Do you know the reason behind this? What modifications should I make?
Not an expert here, but sounds like you're facing is likely due to the way daemon processes interact with the kernel and the Exasock device. Not sure this will work, but you can try, Use exasock with the -d option: This option allows you to specify a daemon process ID or name, and Exasock will attempt to attach to the process and accelerate its connections.
Hope this helps
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
