How to create New Cisco Device using Cisco ISE API
RishabhJain2847
I am new to Cisco ISE API and tried a lot but could not find any information regarding how to create a New Cisco Device in Cisco ISE using API. API documentation for Cisco ISE doesn't show any method to create new device.
Does Cisco ISE API allow you to create new device?
Looking for help in regards to that.
Kind regards,
Rish
Francesco Molino
When you enable ERS on ISE, you can access the following link to see all that's possible using api:
https://ise-fqdn:9060/ers/sdk
For your specific use case, take a look on the following link which shows how to create a network device and network devices group:
http://www.network-node.com/blog/2016/4/19/ise-rest-api-goodbye-click-click-click-click-part-2
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
