missing features in documenation
m.rainer
Level 2
Level 2
First of all: thx a lot for publishing the python pnp server!
I am wondering where to find some parts of the documentation.
Some features are well documented like "device-info", "image-install" but some are missing.
I am trying to do some "cli-config" out of pnp server but I fail. Maybe because I am missing the parameters detail_type and action.
As these features are missing in documentation I only can guess.
Can you please help me
1) with the missing parameters in cli-config
2) adding the missing features to documentation
Thats the best document I found on developer.cisco.com:
https://developer.cisco.com/fileMedia/download/9c751a34-7622-4147-83c5-53ac533646ee
Great Job guys!
Thx a lot
Markus
aairani
Hi Markus,
Could you please provide us with some more info?
- What is the error displayed?
- Could you add your policy file used with the python server?
We have provided "image-install" and "device-info" as samples.
You could refer to the cli-config schema for more information.
Aashita
Hi Aashita,
I want to upload a configuration with the  upgrade-config task on a switch in my local network by using the pnpserver.py script.
It's not showing any errors but it doesn't seem to work either.
Changes that I did:
I've placed and compiled the pnpserver.py on a windows 2008 server, changed the policy file just for the upgrade-config part, created a self-segned certificate for the SSL (HTTPs). Regarding the signal handler request (SIGUSR1 and SIGUSR2) , I've terminated it by putting the SIGTERM instead.
       signal.signal(signal.SIGTERM, sig_handler_usr1)
       signal.signal(signal.SIGTERM, sig_handler_usr2)
I know signal handlers are a UNIX "thing" so I didn't know what to do else.
Can you give me some input to actually make it working.
The executing command is
python pnp_server.py --http --port 9443 -f service-template.xml  --preconfig policy -i 10.x.x.x where 10.x.x.x is the IP address of the web server where the script is executed
Niro95300
Community Member
Hi Marcus,
First sorry for my english
i I succeeded to run cli commands using pnp-server.py. If you want i can help you.
The problem i have now is that i cannot make the "config upgrade" and the "cli-config". My routeur only make the config upgrade but don't make the cli config.
Niro
Tanasis Yankov
Frequent Visitor
Frequent Visitor
Could you please share this document again the link are not working .
