networking
lakhiwnder.smagh
Community Member
I am trying to work on a test case where i need to store the value of  "--testbed" arg and used that to construct the path to be used in one os the function
currently the script works when we use below command
pyats run job <filename.py> --testbed <testbed.yaml> <testbed.yaml>
but i want to just below to run it
any help
Alexander Stevenson
According to the pyATS docs regard run job, the shorter form should be working:
https://pubhub.devnetcloud.com/media/pyats/docs/cli/pyats_run.html
However, it does note that "the arguments show in the pyats run job command may vary, depending on your current plugin configuration."
Alexander Stevenson
