Bookmark
Subscribe
2693
NXOS Netconf Port
NetDevOp
Hello all,
I am trying to connect to a couple of Nexus 9k's using Netconf. I get a response over port 22 and can pull the config but I don't see any configuration options or documentation on how to get the switches to use port 830. Any suggestions on how to do this?
Francesco Molino
After you enabled the feature netconf, automatically the switch listens to port 830, you don't have to do anything.
Have you tried connecting on port 830 over ssh to valide the connection?
Here a link showing how to test it:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/progammability/guide/b-cisco-nexus-9000-series-nx-os-programmability-guide-93x/b-cisco-nexus-9000-series-nx-os-programmability-guide-93x_chapter_0100110.html#Cisco_Reference.d...
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
Sergiu.Daniluk
Hi @NetDevOp
The hard way (cli style):
client-host % ssh -s admin@<mgmt-ip-of-nexus> -p 830 netconf
# netconf operations
The easy way (the ncclient python module):
from ncclient import manager
device = {
    "address": "<mgmt-ip-of-nexus>",
    "netconf_port": 830,
    "username": "admin",
    "password": "password"
with manager.connect(host = device["address"],
                         port = device["netconf_port"],
                         username = device["username"],
                         password = device["password"],
                         hostkey_verify = False) as m:
    # do your stuff
Stay safe,
Sergiu
