128-MB linear Flash PC (PCMCIA) card
mrrussell
I have a cat6506 rommon 7.1 (1). What is the largest size of linear Flash PC (PCMCIA) card. Is it 64Mbyte? I only have 128Mbyte. Will a later rommon work i.e. 12.2 17r S5 as I now have IOS on the SP as well as RP.
mchin345
Level 6
Level 6
The following Flash PC cards are supported on Catalyst 6500 series
switches:
* MEM-C6K-FLC16M(=)
* MEM-C6K-FLC24M(=)
* MEM-C6K-FLC64M(=)
* MEM-C6K-ATA-1-64M(=)
Prior to software release 7.5(1), Supervisor Engine 1 and Supervisor
Engine 2 supported the following Flash PC cards:
* 16-MB Flash PC card (MEM-C6K-FLC16M=). The device name is slot0:.
* 24-MB Flash PC card (MEM-C6K-FLC24M=). The device name is slot0:.
With software releases 7.5(1) and later, additional Flash PC card
support was added as follows:
* 64-MB ATA Flash PC card (MEM-C6K-ATA-1-64M=)-Only supported on
Supervisor Engine 2. The device name is disk0: and the card requires
ROMMON version 7.1(1) or later releases.
* 64-MB linear Flash PC card (MEM-C6K-FLC64M=)-Only supported on
Supervisor Engine 1. The device name is slot0: and the card requires
ROMMON software release 5.3(1) or later releases.
Hi, thanks for the reply, I found http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/6507_01.htm which also seems to support MEM-C6K-ATA-256M for my Supy 2 with IOS, which may be easier to obtain.
Mick
