16.9 Upgrade - MAB not working
Cisco_Padawan
Back story - Our organization is requiring us to upgrade from 16.3 to 16.9 on all catalyst 3850's - we use MAB for printers, VTC, and some workstations. The workstation MAB devices work on the new 16.9 OS but I cannot for the life of me get any VTC or printers to work. I feel like I am beating my face against a wall trying to figure this out. I just don't understand what changed in the new OS to cause this.
My question is whether anyone else has had this same issue moving to 16.9 with MAB and if they have figured anything out.
When I look at auth sessions it says UNKNOWN/UNAUTH
It also shows that dot1x and mab are just stopped
sh authentication registration shows that the priority numbers have changed.. I don't know how to change these or what effect this may be having either. (screenshot attached)
Changin
Francesco Molino
I don't have any issues with version 16.9.
Can you please share the config of your switch and also the log you're getting on ISE to see why printers aren't being authenticated.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
