6509 switch - Lost management capabilities
ktthilavanh
Community Member
I have a 6509 switch running vers 12.2.
I seem to have lost management to the switch ping/telnet access. The switch is working and i'm able to console. Does anyone know why, or how I can fix this?
Thanks.
arififtikhar
Community Member
You must have already checked your PC's LAN connection, haven't you?
Please look if the management vlan/IP is still there and operational. Check it's vtp status etc..
miheg
Level 9
Level 9
If your manage you switch on a vlan interface check if you can define a port of the switch in the same vlan and connect a pc with an IP in the same range as the IP of switch to that port.
Cheers,
Michel
steve.busby
Level 10
Level 10
Besides the VLAN access, have you checked for an ACL that could be blocking VTY access?
Steve
