6509 temperature sensor showing -127
kc-jenkins
SNMP agent on numerous 6509's is reporting -127 on the:
It appears to be isolated to:
module 5 aux-1 temperature Sensor
module 6 aux-1 temperature Sensor
and inconsistantly to:
module 5 RP inlet temperature Sensor
module 5 RP outlet temperature Sensor
module 6 RP inlet temperature Sensor
module 6 RP outlet temperature Sensor
Cisco MIB is reporting:
1.3.6.1.4.1.9.9.91.1.1.1.1.4.7006: 19
.1.3.6.1.4.1.9.9.91.1.1.1.1.4.7007: 24
.1.3.6.1.4.1.9.9.91.1.1.1.1.4.7008: 22
.1.3.6.1.4.1.9.9.91.1.1.1.1.4.7009: -127
.1.3.6.1.4.1.9.9.91.1.1.1.1.4.7010: 21
.1.3.6.1.4.1.9.9.91.1.1.1.1.4.7014: 26
.1.3.6.1.4.1.9.9.91.1.1.1.1.4.7015: 27
.1.3.6.1.4.1.9.9.91.1.1.1.1.4.7018: 27
.1.3.6.1.4.1.9.9.91.1.1.1.1.4.7019: 21
Has anyone run accross this issue?  If so is there a fix for it?
Derek Clothier
Hi Kevin,
     You could be hitting a known bug.  Can you please provide me with the output form 'show version' and 'show environment' from your Cat6k. Can you collect the 'show environment' at the time that entSensorValue (.1.3.6.1.4.1.9.9.91.1.1.1.1.4) is reporting -127 and send me a complete snmpwalk of entSensorValueTable (.1.3.6.1.4.1.9.9.91.1.1.1) plus an snmpwalk of entPhysicalDescr (.1.3.6.1.2.1.47.1.1.1.1.2).
Derek Clothier
