05-08-2008 06:18 AM
I would like to know if there is any limit of site-to-site VPN connections per a 7206?
And if yes, how many?
Thanks for your help,
Mehdi
Solved! Go to Solution.
05-08-2008 12:41 PM
VSA is the new name for VAM. If you do a show inventory, the VSA shows up as SA-VAM2+
05-08-2008 08:37 AM
5000 tunnels per chassis (requires the VSA)
05-08-2008 09:40 AM
Thanks for your help.
05-08-2008 12:23 PM
Is there any command that I can use to find out if there is VSA installed on the router or not?
I know that there is a VAM but not sure about VSA.
05-08-2008 12:41 PM
05-08-2008 12:43 PM
Awesome, thanks alot.
