7600: too small Netflow statistics.
petrowic
Hello ,
my name is Petr Akimov. I'm engineer by ZAO KORTEK.
The core of our WAN is built by 7606 Cisco Routers interconnected each other.
Each router is equipped with WS-SUP720-BASE and WS-X6724-SFP modules .
There are difficulties of netflow collection inspite of IOS software used. The problem I conclude is following:
we receive from the 7600/6500 Ciscos too small netflow statistics - about hundreds times smaller as we expect to receive.
These are the pure facts and figures:
the actual load of an interface is 32000000 bits/sec (5 minute input rate). I'm expecting to receive aboute 32000000(bits/sec) *900(sec) / 8bits =~ 3600 000 000 bytes.
However the netflow statistics I receive in fact is many times smaller: 10619584 bytes.
There are 7606 and 6509 Cisco products only working in production nowdays in like manner (with different IOSes many times tryed) - with incorrect netflow collection. And we establish a fact that the other Cisco equipment we use in our network (as 7200 Series) works netflow perfectly!
Thus there are difficulties with Netflow collection.
The config is:
mls flow ip full
ip flow-export source Loopback0
ip flow-export version 5 peer-as
ip flow-export destination x.x.x.x 19024
interface GigabitEthernet6/2
ip address x.x.x.x y.y.y.y
ip route-cache flow
ip summary-address eigrp 101 0.0.0.0 0.0.0.0 254
media-type rj45
mls netflow sampling
end
Please tell me what to do, because of money waste. In many situations we have to use netflow and we cannot use snmp.
Thank you in advance,
Petr Akimov
k.a.clarke
Hi Petr
I've been facing a similar problem, I think you need to monitor bridged IP traffic, at the moment your probably only monitoring non bridged. The command to do this is only available in release 12.2 (18) SXE or later. The command is (config)#ip flow ingress layer2-switched vlan
Hope this helps
Keith
mishanno
Petr,
I think the issue is that you are using sampled NetFlow (mls netflow sampling). This just samples the flows periodically. To get everything, you need the standard netflow (mls netflow).
I could be wrong here, since I haven't done a lot with Netflow, but I'm looking at the command reference here: http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a00801ea88c.html#wp1044660
