803 Router is Visible in Unconnected Devices
falkaabi
I have Six 803 Cisco Router , they are Very much Reachable and i can see it Green , but it is showing in the Unconnected Devices, is there any way to get back these routers in Connected Devices and can i able to see it in the Layer 2 View of the Topology Service.
these is the sh ver command out put of the router.
RAS-REM-CL1>sh ver
IOS (tm) C800 Software (C800-OY6-MW), Version 12.2(19), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 13-Aug-03 00:07 by kellmill
Image text-base: 0x000F2000, data-base: 0x00769000
ROM: TinyROM version 1.4(1)
RAS-REM-CL1 uptime is 4 days, 6 hours, 23 minutes
System returned to ROM by unknown reload cause - reason ptr 0x1000, PC 0x0, addr
ess 0x0
System image file is "flash:c800-oy6-mw.122-19.bin"
thanks in Advance,
m.singer
Level 4
Level 4
I think the problem is that you dont have all the required patches on you NMS. If you are using Cisco Works you could download
the latest patches online by following process
Click on Device Manager --> Administration --> Package support updator
1. Click on Add package
2. Click on CCO click next
3. Click on upgrade Upgrade packages based on what is currently installed
4. Click on next
Hi Faisal,
For Campus Manager in LMS 2.2, you could try:
1) Ensure you have all the current IDUs and patches.
http://www.cisco.com/kobayashi/sw-center/sw-cw2000.shtml
2) Since Campus Manager determines layer 2 connectivity via CDP, CDP must be enabled globally and on each applicable interface.
Router(config)#cdp run
and on each interface:
Router(config-if)#cdp enable
3) Can the devices see each other via CDP?
Router# show cdp neighbor
4) I'm guessing these are in remote locations and centrally connected to central router--is this other router a Cisco router or some other vendor?
Steve
