8300 console port not working
Steve Pfister
We are trying configure and install a new 8300. We have the light blue console cable plugged into the RJ45 jack and a USB serial adapter plugged into a Dell laptop. No matter how we configure the terminal program or the console port on the router, we get no output whatsoever. Does the 8300 need a different console cable? This same laptop, cable, and USB adapter work fine on other Cisco models. Is there some trick to getting this to work?
16 Replies 16
Yes, it is the correct COM port. Also, the confreg is currently 0x2102
         - confreg looks good ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
