01-12-2007 01:27 PM
Hi guys,
I need to have OSPF events/traps to appear on CW in some way, but OSPF traps are not supported in DFM.
Is there any way to extened DFM capabilities (like using RME - syslog for instance)
Apreciate your help,
Pedro Trigueira
01-12-2007 01:53 PM
RME may be a good alternative depending on the IOS version you have. For IOS 12.4, here is a link to the various OSPF-related syslog messages:
You can then use the RME Automated Action feature to turn these messages into email messages or whatever you need for further notification.
01-12-2007 03:47 PM
Is it possible in RME to turn theses messages into traps ?
P
01-12-2007 10:40 PM
Yes, you could do it, but not out-of-the-box. You could create an automated action script that calls Net-SNMP's snmptrap command to create a corresponding OSPF trap, or build a custom trap of your own design.
The Net-SNMP suite can be found at http://net-snmp.sourceforge.net .
