Access list no interface management
digimansam
Hi All,
So I'm doing a new test config on a Cisco 881 Router.
I have created four IP subnet pools, I have created four interface VLANs 1,10,20,30 with IP addresses so the router knows what subnet is what. the problem is that I can't seem to put an access-list any of the ports that will be going to a switch. The interface VLAN-10 lets me put an access list onto it to block telnet and SSH but it just keeps working it Does not do anything at all.
What I'm trying to do is only have one management subnet within VLAN 1 that is not going to be Natted to the WAN side.
Has anyone come across this before any help would be appreciated
ip source-route
ip dhcp excluded-address 192.168.100.0 192.168.100.9
ip dhcp excluded-address 192.168.100.64 192.168.100.69
ip dhcp excluded-address 192.168.100.128 192.168.100.139
ip dhcp excluded-address 192.168.100.192 192.168.100.200
ip dhcp pool VLAN-1
network 192.168.100.0 255.255.255.192
default-router 192.168.100.1
dns-server 8.8.8.8
lease 3
ip dhcp pool VLAN-10
network 192.168.100.64 255.255.255.192
default-router 192.168.100.65
dns-server 8.8.8.8
lease 3
ip dhcp pool VLAN-20
network 192.168.100.128 255.255.255.192
default-router 192.168.100.129
dns-server 8.8.8.8
lease 3
ip dhcp pool VLAN-30
network 192.168.100.192 255.255.255.192
dns-server 8.8.8.8
default-router 192.168.100.193
lease 3
interface FastEthernet0
switchport access vlan 10
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip address 192.168.100.1 255.255.255.192
interface Vlan10
ip address 192.168.100.65 255.255.255.192
ip access-group 100 in
ip nat inside
interface Vlan20
ip address 192.168.100.129 255.255.255.192
ip nat inside
interface Vlan30
ip address 192.168.100.193 255.255.255.192
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
logging esm config
access-list 1 permit any
access-list 100 deny tcp host 192.168.100.65 eq 22 any
access-list 100 deny tcp host 192.168.100.65 eq telnet any
access-list 100 permit ip any any
line con 0
exec-timeout 60 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 60 0
logging synchronous
login local
transport input all
end
Mark Malone
these are pure L2 ports as its a soho router , you cant add any IP commands at all to those ports , are you trying to specifiy which port you come in on with SSH etc and outbound ? without an actual MGMT port all you would need acls in both directions and also source the MGMT traffic out by that vlan to try and force it , or MPP feature if supported but i think its only on ios-xe and xr
Mark Malone
