ACS KVM Console drops network connection
rizaldy.guban
I am having problem running KVM console on ACS CIMC ver 2.0(1b). I get "The viewer has terminated. Reason: The network connection has been dropped." error. Basic network connectivity is for sure working. I hard coded the speed/duplex to 100/full as well.
Has anyone come across the same issue? Appreciate any feedback.
Thank you!
Rizaldy
Yasser Al-Alem
HI ,
UCS uses port 2068 for KVM connection, try to telnet to CIMC IP using this port to check if this port is  blocked
