08-29-2011 06:58 AM
I would like add an alarm to LMS when a power supply of some device goes down. For instance, when the power supply fails LMS send an email or something like that. How can do it?
Thanks in advance
Solved! Go to Solution.
08-29-2011 07:39 AM
Go to Admin > Network > Notification and Action Settings > Fault Notification Customization, and check the boxes for StateNotNormal and OutOfRange. Then configure a Notification Group for that Event Set. That should provide you notifications for events relating to failing hardware such as Power supply, but it will also capture things relating to high temperatures as well.
I hope this will help..
Afroj
08-29-2011 07:39 AM
Afroj
09-06-2011 12:54 AM
thanks afroj
