Add devices manually
mserranocisco
Level 3
Level 3
I'm new on version 3.1, and I don't understand how does it work.
I want to add nodes only manually, I don't want to use Seed Devices. I add them from CS>Device Management, they say me nodes had been added properly, but they appear always as Unreachable. Ping and snmpwalk returns OK.
Should I configure something on Device Discovery?
Marvin Rhoads
Have you entered the proper credentials for the devices in the Device and Credential Repository (DCR)?
Refer to Chapter 5 of the Common Services User Guide:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.2/user/guide/dcr.html
Hope this helps. Please rate helpful posts.
Yes, I supose...
I have defined Default Credentials and checked Use Default Credentials when adding devices.
Devices added appear properly on CM, but not anywhere else.
I have added them from CS>Device Management, but list is empty, if I try to add a node again, it says it exists... I don't understand anything 😞
