Allocating bandwidth for application using Prime Infrastructure
yalmatra
I need to know if is there is any way to Allocate Certain amount of bandwidth through Prime Infrastructure
Mark Elsen
 - As far as the device(s) being managed by Prime  supports bw-management ; you can use the config-management capabilities from Prime to  define the specific settings.
M,
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
