Allow feature upgrade with Software Distribution
howlingthunder
Is there a way to add the /allow-feature-upgrade flag when pushing .tar images to switches? I had several that failed due to feature set and had to manually upgrade them. Thanks for any help!
podhillo
we can try to use the Adhoc feature;
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.3/user/guide/netcfg.html#wp1085251
Please let me know if this was helpful.
podhillo
